New here, my son is riding a 97 xtc 500 which has developed clutch issues. Sled was a little old ladies machine that I got a great deal on, only has 2300 miles on it. Put a new belt on after the orginal started to show signs of wear and squeal a bit. the new belt did not cure this. Also i noticed the belt is low in the secondary, can anybody give me some insight into how to cure the two problems which I suspect are connected. I am a ski-doo guy so I don't know diddly about these clutches.
Thanks for any help
Chris
Thanks for any help
Chris
hereismylife
There is a lot of good info in my signature. Hope this helps you.
TRUE BLUE SINCE 1980
did you check your ramp pads,if they are wore down and its running aluminum to aluminum it will make screetching noise ... adjust your belt ride height with the small washers on the back side of the secondary.
