YAMAHASTUDS
Just got done building my 97 sx 700 from the ground up and I go to start it and I am getting no spark at all..need to know what wires do I plug my ohm meter testerinto on the stator wiring in order to check to see if the stator is bad?? I hooked my ohm tester up to the coil pack and it wasn't getting any power at all...tried a different cdi and that still didn't work...I'm thinking that the stator I got is bad...any help is appreciated.
Check post #12. Its has some wire colors and specs
http://www.totallyamaha.net/forums/showthread.php?t=34535&page=2&pp=10&highlight=Stator
NY_SXR700
If you just built it from the ground up with "known" good parts. I say that because who would use suspect bad parts. Then I would check all your grounds, connectors and wire harness plugs first. I have the stator specs for that sled if you need them, if you think it is bad. Doug
sleddineinar
Definately check all of your connections again.
