redrill ?
coldsmokesurfer
bozeman mt
i have a older Yamaha skid im trying to put in my mm700 with newer elkhom tunnel any one know the best way and how much to move holes thanks
141 inch track
believe older 136 inch skid
If you have the skid you took out you come up with the differace of the two sitting side by side of the rear axle hole to the end of the rear wheels.
So if you put the skids side by side lineing up the rear wheels and held the upper shock swing arm to the right height of the sled it came off with a piece of wood.You can meashure the differance of were the old rear axle was mounted to were the new one will have to be to have proper track adjustment.
