Here Ya Go
Have 02 Viper with SLP's. Stock motor. Cut head by CPR to get equal compression. About 130 on all cylinders. Have Temp-a-flow, rear exchanger, and Opticool gasket.
160 mains
3.5 stock needles
47.5 pilots
2 1/8 fuel screws.
Might be a bit lean for you app. Most set up's tell you to richen the Mag., but since I have same compression all the way across and all that cooling stuff, I set jetting the same all the way across. Rode last weekend in +5f to -5f with no problems.
