97 Vmax 500 Oil Burner!
az304
West Falls, NY
Hello,
Anybody know how to rebuild a VMax 500 oil pump?
Mine delivers 3 X the oil it should. Cable is adjusted to minimum flow.
Don't really want to spend $180 for a new one!
Also, can I let it run dry and use premix gas/oil?
Thanks for any input.
I dont think those things are even rebuildable, if they are, I dont know of anybody who rebuilds them.
I would just look on here or Ebay and pick up a used one. When I had a 97 venture a few years ago, I bought a used one from the local snowmobile junker for 20 bucks. Worked great.
No rebuild look for a good used one from a '98 and up,do make sure it's from a 500cc engine as they had different flow specs from one to the other.
good luck
Thanks for the info.
good luck
Thank you very much for the help.
Sorry to steal your thread , but what in the pump fails to allow them to go wide full open?
I can't believe that not one single gear head here has never taken one apart.
I agree with you. I'll be taking mine apart this summer.
