parts
smokey1
IN
where is there a good cheap place online to buy yamaha parts.
im looking for drive axle bearing and a few other parts. thanks
not sure about Yamaha parts online. For bearings, go to your local bearing shop and order them there. Much cheaper and better bearings. For the drive axle and jack shaft, I use Timken or Fafnir collar lock bearings. They stay in place much better than the bearings with set screws.
I think it's about $24. this is the part number for the drive shaft: rae25rr. FYI, the one for the jackshaft is rae25rrb (rounded outer race). Make sure you get metric ones... the other appears to fit, but it's a little too big and comes loose (learned by accident).
ordered
alswagg said:
I have always had excellant service from Port Yamaha. They are also a supporting member. http://www.portyamaha.com/
Talk to Kevin, tell them you are a Totallyamaha member, might just get a bigger discount. Al
just ordered off of portyamaha thanks
