Drop brackets
suzuki750
Manitoba
Wondered if there was anything out there to drop the skid lower out of the body of the machine to give more clearance. I had ordered the ones from cb performance but they must be just for a stock sled and not a mountain viper which is what I have. Thanks
I tried the ones from CB performance but they are shorter then the factory ones on the viper mountain. Are there ones for a mountain or is that as high as I can go ?
I made my own because I have a hybrid setup (Nytro XTX skid in a Mtn Viper). However there are a number of offerings. Do a search for some of my posts about this on here and on snowest.
Timbersled and Kmod make ones that might give you the drop you need. Actually Kmod will make whatever size you need. I simply made mine out of 7075-T6 for the plate, and 6061-T6 angle for the brace. I used a 3/4" flat bar for a spacer on the outside edge of the running board to bolt the brace on. My mount point is 6 inches out of the tunnel, so I was concerned with strength.
