Blue smoke
Scherbers4
Minnesota
Hey guys,
ever since I got my sled clutch and a hauck can it has started to smoke more blue smoke at idle, and I got my new oil lines put on sue to my risers. It still has really good power, just wondering if I should go over it or check anything out?
half way down the cable to the oil pump there is an adjuster for the pump. do a search here you'll find the info to do it. but check there to make sure you didn't accidently pull the upper half of the cable out of the sheave. that would have your pump working overtime
Pull the cable closest to handlebar out of the fitting and measure. Should be 20 - 22 mm. Adjust if necessary.
With the thinner oil I am running, I had to take the cable out to 23.5 mm.. This got me to my proper mixture rate. Took quite a few rides along w/ exact measurement of fuels and oil. Ride,measure consumption,adjust cable w/ caliper.....do again and again till proper ratio is achieved.
But my bet is that the cable got pulled out and isn't seated
On a stock Viper i like to see 45:1 consumption.
thats just over a qt(34oz)to 12 gals(tank) of fuel, target that.
