h/c red or grey
BLUEBY
minneapolis
i put on the hc's on my viper w/ 3.2,4.3,4.3 and a 46/36 helix, what's the big difference between the red and grey spring. i'm looking for a more agressive trail setup but don't want the high engagement. What's the best route?
h/c springs
the red spring is 230-360, the grey is 230-330, the engagement will NOT change as they are the same rate beginning, what it will do is upshift faster then the red, but will also backshift slower. If you want a lower engagement, add weight to the heel. If you are a aggressive trail rider, stick with the red spring, much better results for backshifting.
