how many volts fo eciter 440
700seven
michigan
how many volts should i be getting on the yellow, brown, and glue wires coming out of the motor I'm trying to figure a no spark issue also is there a way to test the cdi? any help would very welcome thanks
not sure but do an ohm reading on the stator coils I've seen the coil with the brown wire go out alot this year
you can check the ht coil with a test light by checking the wire going to the coil if it lights the light when you pull it coil is bad if not problem is lower
