ryanblackburner
i have a 2002 viper with no crank and a 1999 srx with a melted piston head and scored jug will my srx crank fit the viper or the viper jugs fit the srx base? please help had two sleds now none!!!
mopar1rules
w/o some extra work and explaining what all has to be done, the swapping of them parts around won't work. just gonna have to get a viper crank for that viper case and get srx cyl's for that srx case. its the easiest in the end.
ryanblackburner said:i have a 2002 viper with no crank and a 1999 srx with a melted piston head and scored jug will my srx crank fit the viper or the viper jugs fit the srx base? please help had two sleds now none!!!
sure it will, just put the srx crank into the viper case, youll need to reuse the pto side bearing off the viper crank. just slip off the 2pc srx bearing and install the 1 peice viper bearing onto srx crank, will drop right into the viper cases then. You wont be able to use the bottom case swap between the viper and srx as they are differnt ign. systems. The flywheels are differnt diameter, p/u coil located differntly on case boss, so the ign. systems wont interchange to make it short, but, if you can salvage the viper cases the srx crank will get you back in bussiness.
