Phazer on one cylinder sometimes?
CELLARDWELLER
MASSACHUSETTS
I have a 1990 Phazer II for my daughter. The sled starts idles and runs from half throttle to full throttle fine. While coming off idle and slow running, the mag side clinder starts to sound like it loses spark, and if you give it more throttle it comes back to life. You can tell the mag side plug is blacker in color. I replaced the cdi from a spare sled, plugs, coil.... There is 130 psi compression in both sides.... I've cleaned carbs 2-3 times and soaked them in boiling water once....Choking that side doesn't seem to help. I'm asking for help.... going to try new plau ends next... anything else?
Floats to spec height and seating not leaking?
magneto in spec?
choke plunger circuit clean and not sticking?
you sure it's electrical or carboration/fuel delivery issue?
smoking heavily?
