bolts size to remove flywheel on 02 700 Redhead?
TJ500
Lockport, Manitoba. Canada
going to be replacing my stator this weekend. Does anyone have handy the size and thread pitch etc. for the three bolts required to remove the flywheell with a puller?.. Is there a trick to getting the flywheel to pop off without damaging anything?
thanks tj...
The bolts that hold the recoil on work good with my puller. There is no trick, just use the proper puller and don't hammer on it as it could damage the flywheel, also ensure you don't thread the bolts so deep into the flywheel that they extend inside far enough to hit the stator.
