I hope that I can explain this........ engagement at just about 3500 maybe 3800 right in there, at 20mph on the trail steady throttle It is turning 5000. Its almost as if it never shifts. I had enough of a area to run up to about 70 it was up around 7000 to 7500. When I let off from any speed its almost like it has a drag brake. Clutches are clean , what advise as to where do I start?
Thanks again !!!
Thanks again !!!
sounds like sliders in secondary or a bad bearing in the drive train.
