780srxgeorge
srx780. i ask this question befor would like to go 136 on my sled.well it push in the corners w/ studs.i don't know the window count but 2 studs on each bar down the middile.i got a xtc frontend so pushing wont be bad just slow down a little.well get 8 tooth drvs & changing gears from 23-38 =1.65 to 22-39= 1.77.what doo you guys think. THANKS 4 INFO
ottawaair
corner push is all relative to setup. Good carbides/skis, pull limiters up & loosen center shock preload, sled will corner great cuz all the weight is on the rear of track & skis. lot of ski pressure. Now loosen limiter straps, tighten preload, open gap on transfer rods, skis will lift on take off & push in corners. Think of the limiter straps & center skid shock like an adjustable balance point on a teeter totter.
780srxgeorge
thanks ottawaair for your info.i for got to mention i have maxium transfer rods.my cousin has a 136 i can pick up cheap.it's like new.i hope it well fit on trailer for next year. thanks again!
staggs65
if you're going 136 for off trail purposes you could also go with tip-up extensions. then you'd feel pretty much the same feel on trail but have the 136 for off trail
780srxgeorge
tip-up
hay staggs65 where can i get the tip-up rail extensions.SLP has the standerd ones for $85.just trying to get an idea on $$ to spend.a lot of side work this summer! too getter dun. thanks
bluemeany
You could also go with an offset axle with regular extensions.
This way you could run larger wheels in the rear.
Places that fab offset axles; tricked toys, mountain machine performance avid products, and tracks canada
bluemeany
136"
staggs65
cb performance made a set of tip-up extensions for a sc-10iii skid i helped install in a rx1 for another member here. i'm sure they could do the same for the proaction. also check tracksusa.com, they usually have packages with ext. track, and tunnel ext.
staggs65
heres a pic of the rx1 with the sc10III and cbperformance tip-up extensions
bluemeany
I ordered the tracks USA extension package and a tunnel extension from Hartman Performance. I returned the tunnel extension to tracks and kept the one from Hartman. Hartman Performance sent instructions and had all parts for the crossover exchanger tube. Tom Hartman is very knowlegeable and has a great product. Hartman's products are not cheap, but quality is great!
