Which piston to use??
northernSRX
north sask
Blew a piston yesterday on my 700 sx, and was wonder which brand of piston i should use to replace the blow 1. Also the cylinder that piston blew head is all pitted should i replace it or will be ok to reuse it
jus some pieces of the rings left in the piston. Cylinder fine have a replacement ports look fine. do u think i jetted to lean?? the head is pitted pretty bad about half way up the dome all the way around. couldn't upload pics
piston brands is like oil brands, i aint touching that one with a 10' pole.
l have reused heads on 2 stroke MX race bikes after losing a piston when in a jam, however i would caution against this, if there is any tiny peices of ring debris imbeded in the head there is a possiblity it will destroy the mill again.
Before you replace anything you need to indentify why it went pop, otherwise its pretty much a given it will go again.
