SRX 700 Carbs
Pauljones
Manitoba, Canada
I am looking to purchase a spare set of carbs for my 1998 srx700. I am wondering if the carbs are identical for the years 1998 - 2002. I know the main jets and pilot jets are slightly different, but I am wondering about the needles, clip position of the needles, air jet supplying the pilot, fuel screws, etc...
Any help would be appreciated, Thanks.
2000 & up have a throttle position sensor, maybe it's '01 & up, either way the newer ones will work for you, just can't use the older on the newer sled.
the only difference on the '00 and up carbs, is the TPS sensor on the pto side carb. i have a extra set of '98 carbs if you need a set and i have a '01 srx set too.
