Drive chain
yfm350
canada
What should the chain tension be? I drained my chain case and took the cover off. The chain seems loose to me
While you have the chaincase open, back out the tensioner bolt so you can remove the chain. Inspect the chain for broken links. Measure the chain length for excessive wear/stretch according to the manual. Pretty easy to do. Wip/wash out the accumulated debris from the bottom of the chaincase, not all of the sludge drains out when you remove the drain plug.
