Bearit
Hi Guys,Im just about to order my new 1.25 ripsaw fully clipped for my 2002 viper,and thought about installing 9 tooth extroverts when I have the shaft out.I was wondering if it is a simple install or do I have to trim the rails or cut of 3/16 of the extroverts for clearance as I have read in other posts.I have a 121 m10 in the sled.
Thanks Steve
Thanks Steve
2ooosrx
- Oct 2, 2004
- Gurnee, Illinois
- www.cbperformanceparts.com
Did you find a good price on the track??? We can sell it to you cheap! Send me a PM if you are interested and I will give you the price. As for the drive cogs, they are not easy to install. You need a press to get them off and on the shaft otherwise they are impossible to get off. With the 9's you might have to cut the 3/16 because it is on a viper.
sxviper32
what about 8 tooth no slip drive sprockets on a ripsaw?
2ooosrx
- Oct 2, 2004
- Gurnee, Illinois
You will not have to cut the 3/16 off then because they are already 1" shorter but grearing must be changed
grapeape
9 tooth drivers and the M-10 will need more than 3/16 cut off in most cases. The srx we just did up with 8's and a M-10 cleared, but not by much
