thetorches
i have a 2002 viper 700. it's my first sled. i know they smoke when running, but it seems to be too smoky. it's running rough and i am going to get carbs and power valves cleaned. would this help or can someone tell me what would cause excessive smoking. thanks for any help.
02ViperMtn
did you fog the motor before storing it last year? Or the previous owner? If its the first time running since being fogged/stored there will be a build up of oil in the exhaust that takes a bit of time to burn off.
hereismylife
Start with oil cable adjustment....
just at idle or when moving? maybe your fuel screws are too rich
FJViper
Yeah, my 02 Viper smokes alot when idleing. Notice it more when first firing up the sled for a ride. Fuel screws are at 2 turns out to combat an idle hang. Once moving though I don't notice any excess smoke.
best part of a two stroke............... dont change a thing. i think someone should make a air freshner that smells like two stroke exhaust.
blk04700 said:best part of a two stroke............... dont change a thing. i think someone should make a air freshner that smells like two stroke exhaust.
Thats just sick and twisted. That Amsoil really turns my stomach. Nasty smelling stuff.
Netefrog said:Thats just sick and twisted. That Amsoil really turns my stomach. Nasty smelling stuff.
yamalube smells better when its burnt...... never smelled the amsoil so i couldnt tell ya.
I prefer a little excess smoke. Better too rich than too lean.
Mine is from my fuel screw set for lot's of fuel......
thetorches
not sure if it was fogged or not.02ViperMtn said:did you fog the motor before storing it last year? Or the previous owner? If its the first time running since being fogged/stored there will be a build up of oil in the exhaust that takes a bit of time to burn off.
thetorches
it seems to be worse when it is idleing.yammy said:just at idle or when moving? maybe your fuel screws are too rich
02ViperMtn
was it the first start of the season? Is it brand new to you?
02ViperMtn
fill up fuel and oil and run until you have used at least half a tank gas. Then fill fuel and oil at the same time and do the math on your fuel/oil consumption and report back. It could be running a bit rich too. Better rich, but excessive rich can be bad too.
check if the oil cable hasn't been pulled out and stuck in full open position..mind you if it was,no way it would idle on its own..but check oil cable for spec settings.
02ViperMtn
good one blue. Check the cable ferrul is seated inside the bracket properly at the adjustment location. I think they may still idle even if it is pulled out
thetorches
will check this out. doesn't want to idle unless choke is on. thanks for the help.bluemonster1 said:check if the oil cable hasn't been pulled out and stuck in full open position..mind you if it was,no way it would idle on its own..but check oil cable for spec settings.
thetorches
it's my first sled. don't know much about them. getting carbs and power valves cleaned on sunday, will check oil cable also. thanks.02ViperMtn said:was it the first start of the season? Is it brand new to you?
thetorches
thanks everybody. the cable was not seated right.
