Phazer 2007 Starting Problems
GAB THE KILL
nEW-bRUNSWICK
My sled will not start , fuel injection is activited, no reaction at starter, then a clik and eventually it will start. No Problem when it is warmed. Is it humidity, cellenoy or else? Someone had such a problem and what is the cure?
I'm sure if you post your question on the 4stroke side under Phazer you will probaly get a faster and better response, but yes it sounds like maybe the soleniod and dirty connections
I get the same problem with mine after some warm weather. As if humidity gets in the solenoid connections then freezes. I just slam the sled down a few time and it starts. Or you could open the side cover and take a hair dryer to the connections. Once warmed up, all is good.
