AndyC
OK I opened up the gear case to see if I had problems inside due the fact of metal filings in the dip stick. Everything was fine - no noticeable problems and I'm thinking the oil hasn't been changed since I purchased the sled. Now I have it all back together it's not going all the way in reverse and grinds. I never had this before so it's something I did putting it back together. I'm about to open it back up but figured I check here first. I'm thinking the reverse arm isn't in the right place.
Thanks guys.
Thanks guys.
Sounds like either the reverse fork is not in right or one of the linkages is flipped around
AndyC
Well I took it all apart again - everything was in the right way. I figure the little bit of filings were from the gear engagement and since the oil hasn't been changed that was the unnecessary disassembly of the gear box. I'm thinking I had the chain adjuster a little to tight. I put it all back together and it work fine for a few runs around the yard but needed to be adjusted out a bit more. I think I have in set right now, back to easy engagement and no more grind :P
I did mess with the adjustments on the rods a little.
