Need Repair Manual 01 sx 700 r
Joeyb621
Niles, MI USA
I came across this site, just as I am tearing in my 01 sx 700 r. Can someone send me a repair manual. I was messing around with my polaris buddy and one belt burned up, so put on the spare and took it easy for a while then
got back to whooping on the polaris and the sled just shut down... pull start was very hard to pull, but sled fired back up and limped her back to truck. Got home pulled plugs rich on oil thats it....put new plugs in back firing through exhaust, shut her down ect... anyway pulled head off pistons ok no holes...pulled slowly and piston by clutch was sticking on the very bottom of the up stroke tore her down to crank... one of the bearings on crank seemed to be bad and the bearing on the outside of crank... where is the best place to buy these any upgraded bearings to buy also thinking about doing the 780 kit can I do the head gasket delete and the 780 kit any other advice while I am in there...planing on keeping her
Email Manual to
Joeyb621@aol.com
Thanks in advance for your help
You have the updated bearing on an 01 SXR. 780 is a viper/SRX BB. Are you talking a 700SRX?
you squeaked it!! check the piston skirts & rings. bender makes a great 800 kit for that motor. mine made 157 h.p. @ dynotech w/ sissy safe winter jetting on pump gas.
bob
any repair manual s?
After researching a bit more the 800 kit seems like the best option or just some porting and polishing are in order. I d like to have the repair manual before I make any decsions thanks
