are viper and srx powervalves different? guys on fleebay say theyre the same.  thanks guys great site
			ottawaair
what are the differences.  they have the same part #, but srx starts with 8DN, viper with 8EK,   both are 1131A-00-00.  I always thought they were the same.
			vipers are thicker and wider.......
			mopar1rules
trust me, the valves have different dimensions.  you CAN'T run a viper valve in a srx cylinder, or vice versa.  has to be viper valve in viper cylinder and srx valve in srx cylinder.  even srx valves are different.  600 srx valves won't work in a 700 srx or vice versa.
			yes they are different ,,,viper is wider and the bevel is a different angle and a few ither differances ,,,anyone who tells you they are the same has no clue what they are talking about ...if you got some that need fixed get ahold of me and i can fix you up better than new
			YAMAHASTUDS
But all srx 700 valves are the same correct??  I can use a set of valves from an '02 700 in a '98 700 correct?
			motorhead327
Yes all srx 700 valves are the same. Your good.
