97mm700
hey, i got a 97 mm and i want to update it to the 2000 model, without spending much money, i got a 2000 body from a buddy but the motor mounts cracked off so i cant use that body, it got the plates and all, but i was wondering the exact holes to drill so it can just bolt my suspension on and put my 141 track on without buying the harman inc kit like my buddy here got
need a bit more info for clarity. your 97 would have been a 136. are you trying to retrofit the 141 under it using your skid or stick the entire skid from the 2000 in your 97?
snowdad4 said:need a bit more info for clarity. your 97 would have been a 136. are you trying to retrofit the 141 under it using your skid or stick the entire skid from the 2000 in your 97?
^^ What snowdad said. I went through the steering post with the front mount holes.136 skid 141 2" track. Thanks Snowdad for your help. Just got back from some insane drift busting I couldnt be happier
gild
mount points
The frt suspension mount point on the 00 MM is back 7" from the mount point on 97-99 MM. The 00 and up use an H arm compared to the W arm on the older MM
my measuring device shows it at 9 1/2" back.gild said:The frt suspension mount point on the 00 MM is back 7" from the mount point on 97-99 MM. The 00 and up use an H arm compared to the W arm on the older MM
venture700
his gonna use his 97 136'' suspention so are you guys saying the front hole is 7'' (glid) or 9 1/2'' back (snowdad4) from the stock 97 front hole WITH or WITHOUT the front arm relocation like I had to do in my hartman 97-99 MM update kit? if so thats a new problem and do anyone have the measurements for the front arm relocation?
if your relocating the front arm on the rails for the geometry upgrade, the numbers are again different. i have those measures and procedures of my own doing if you need them.
