More TPS Questions
bmm350
connaught
Just tested tps on 01 srx with 3 aaa batterie pack
Voltage from batteries is 4.72 X .136 =.64
I set the tps according to the specs on this site
I was just wondering if the 'wot'should be reading more than 2.9 volts or should it be closer to the batterie input.I seen from the video that polaris adjustment is set at 'wot' from the 4volts input
Should the yamaha tps be the same idea
Any info would greatly appreciated thx.
yamaha sets theirs up like you did and got .64.Polaris sets theirs up with 4 volts wot..If I took my TPS off the carbs and hooked up power to it and turned the shaft on it ..it will surpass the 4 v mark.Just that the throttle only rotates the shaft partially..not all the way.So set your idle v and the rest will follow.I think mine was around 3.11v wot.
You've done it correctly...set it in the idle position on the Yamahas.
