gmcdunnah
cdi quit working ...was wondering if there is any that can repair it? can it be repaired? thanks
which sled? You can use the sx box with the power valves pulled open if it is the older version.
you should just buy a programable timing box (aftermarket) and not worry about the valves. Then you can change the timing to what you want, even run a pipe warm up function. There are alot of them out there, Megajolt is one version.
gmcdunnah
scott, got the sx box on it now, just dont sound like it use to....ill look into them boxes ..thanks
