thinking about a 700 swap
360miller
muncy pa
has any one swaped there 600 sxr to a 700 before
what do i need
heads
pistons/rings
cylinders
can i use the same carbs with differnt jetting
and the big question is it worth it
I wanted to do that with my 600 also,but ended not doing it.I would think you would need bigger carbs for sure,and all the above you mentioned..can get pricey...may be cheaper finding a used 700 redhead instead.... :dunno:
The carbs are bigger on the 700 than the 600. Maybe you could bore your 600 carbs out? IDK just throught I would throw that fact out there.
think maybe just port the heads and call it done is there anyone that i could trust to do a port job???
A couple of bucks said:
lol im a welder no steady hand here would rather pay someone depending on cost. im looking for mid and top end
i can take a srx 700 and a f7 off the line for about 5 or 10 ft then they slowy pass me there is about maybe 12ft
between us then i can stay with them the
the feild we race around in might be maybe 8th mile not shure exactly
