Hey I just purchased a 98 vmax xt 600 twin, and it has a kind of loopy idle. Tomorrow I'm going to remove and clean carbs, is there anything else I should look for? Thanks very much! Kevin.
Ps expect many more questions about this sled to come lol.
When prepping to remove the carbs give everything a good look-see for cracks on the carb boots, loose clamps on the carbs an especially make sure that th boots are on the cars between the carbs and the air box. Good Luck with your carb cleaning project.
brad14880
also check the fuel lines for ANY cracks, or supsicious cracks or leaks, that will cause bad running conditions, what does the machine idle at rpm wise? standard idle is 1600 rpm but idle it up a little bit to almost 2000 and it wont load up on you as easily
