Melted down a 1997 vmax 600 sx motor due to oil pump failure
I have a motor out of an older 600 vmax pogo. I think 95 or 96.
I am wondering if the cylinders and pistons are interchangeable.
Oil pump too.
burnt cyl
8CR00 598cm3 y-1
spare motor
8CA00 598CM3 y-1
They look the same on the outside. Don't want to crack in to this spare motor to find out.
Oil pump too.
burnt cyl
8CR00 598cm3 y-1
spare motor
8CA00 598CM3 y-1
Not sure about the oil pump but the cylinders have different bolt pattern for the reed valves.
mopar1rules
mtnmaxman600 said:Not sure about the oil pump but the cylinders have different bolt pattern for the reed valves.
correct. they won't work. i have a good used cylinder for a '97-'98 vmax 600 twin engine if interested. please pm me.
What if I swap the reeds? From the outside they look the same.
I need 2 cylinders and pistons.
I have in excellent shape....
2 cylinders for the redhead 600 triple with pistons.
I also have an oil pump.
I have these older style twin 600 cylinders and pistons.
Any one interested in a trade or buying these parts from me so I can get the right stuff?
