SRX540
Rebuilt the exciter sx runs like crap lean on the right plug almost and fouling out the clutch side....It sat for like 6 years so maybe ill just buy a new fuel pump and filter and see where that goes.....Also i didnt take the tops of the carbs off when i cleaned the carbs up, is there circuits or anything to blow out up top?? Also i dont think my seats are sitting right they arent sitting level b y any means.
Usually the inlet needs and pilots will need to be replaced if it sat that long and the float will need to be reset.
YAMMIEGOD3:16
YA NEED TO PULL CARBS BACK OFF AND PULL BOWLS. FOR STARTERS I WOULD MAKE SURE FLOAT HEIGHTS ARE ON SPEC. 3:16 (yammie tony)
SRX540
Tony
Ya Ton the thing sat for like 7 years or something, when i had the carbs off and upside down the floats werent sitting level upside down they were dipping how do i set them??
YAMMIEGOD3:16
I,LL DIG YA OUT FLOAT HEIGHT SPEC TONIGHT, VERY EASY TO SET. THERE IS A VERY SMALL '' TAB '' THAT YOU CAN ADJUST HEIGHT BY TAKING SMALL SCREW DRIVER AND BENDING UP OR DOWN. 3:16 (yammie tony)
