m 10 came loose
yamachuck
cleveland ohio
big trip this weekend .checking out my viper.the m 10 came loose ,narled the shaft and the aluminum arm hole..I can fix it .but when I bought the suspension used it came off a rx 1 .I have the kit from that. I swear someone told me to buy a rx 1 kit instead of the viper kit.for a easier install. any advice please. thanks.
Rx 1 front shaft is the same as would go in a viper tunnel. Same width, same location.
If you want to make that ARM style mount stay in place,you need to drill it so it bolts through the handle bar hoop on the frame .
