need clutching help
Bushc
Michigan
I need help getting a good clutching set up I have done alot of searching and there is so much info out there its hard to come up with good results. My 01 SRX current set up has a yellow and blue primary spring with a bender 8mm shim. Which I was thinking of switching to a White-White-White spring. 8dn-20 weights but I have no idea put much weight is in them. How much should it weigh. The secondary is a bender 47/43 with a yami green spring wrapped @ 60. I ride mostly in the trails. What would you keep and what would you change?
go with 8dn20's loaded up and with y-w-y stock spring in primary.60 wrap seems to light..try red spring at 80 first and see where rpms are.With what you have now..what are the rpm's doing at launch and wot??
I called bender today and the short yellow and blue spring is supposed to be there with the spacer. The secondary is supposed to be a yellow bender spring wrapped at 30 but it has a yamaha green spring in it is that close to the right spring? I can't seem to find the yellow and blue spring on their website is does anyone know of a yamaha equivalent?
