srx clutch kit question?
kking32
moncton canada
just installed new primary weights bushings and spring, now i'm on to the secondary, where does that shim or spacer go? the kit came with it, thanks for any help,
I think what you are talking about are the shims used in the primary clutch you can use up too 3 total they will raise the engagement rpm 100rpm per shim
