Blown Motor
tsquared
Winnipeg, Manitoba
My buddy just blew his motor,crank or connecting rod not sure yet, in his 97 sx 700. Thinking the worst what years and motors willswap in? Will srx bottomends fit?
thank you
Will srx bottom ends fit? yes, they will fit in the hole but you will need top ends, electrical ends power valve ends. Pretty much the shootin match. I beleive for the most part any red head 700 from 97-2002 will fit. Depending on what year you may or maynot have to reuse your stator/flywheel electronis. I just had to tear down the old ladys sxr 700. I found Bender racing has a rebuild long block kit for $1200, not to bad considering new crank with bearings run around $800.
