viper reverse buzzer help.
super1c
Super Moderator
Freeland & Otsego lake, MI
I think i found the reverse wires that go to the lever switch, they are pink and black found tucked under by ignition switch. But for the life of me i cant fint the wires that plug into the buzzer itself. I have looked everywhere. By the directions in the tech section it should be on the right hand side foot well. but i find nothing. I have e start installed now so is it tucked inside the footwell on the inside of the engine bay and i cant see it with battery in the way? Just laying the ground work so i havent taken out e start yet or chain case (praying for more snow by chance but its 40 and raining as i write this). I am stumped bigtime on this!!! Help, pics would be great. Where would it even mount with the rectifier and smoothing condensors in the way. I know i can remove the condensors but....... I am lost on this one. Thanks chris
I went through this a few years ago . Found out that the buzzer goes on the left side about half way up from the foot well . If you want I can take a look on my 03 and try and give you some colors to look for . All there is is a couple spade connectors on thin wire . Hope this helps .
SS
Lookd at mine today. The buzzer is located high in the footwell on the left side. As far as I could see there were two pink wires coming from the buzzer. Not sure if they were part buzzer or the harness. Was too lazy to take the cover off.lol
