destroyed primary clutch today
justin1620
ON, Canada
hey fellas.....I was rippin pretty hard today across the lake and then KABOOM!
I opened up the hood to see the damage.....my primary clutch outside face broke a piece off the size of your fist...clutch pieces everywhere ..etc. I need to know which primary clutches will work on my 99 srx. Will all 98-02 srx primary work and which other models? I was pretty happy with my heel clicker set up as I was pulling 106mph on gps on hard pack lake.....what would cause this to break so badly....to much force from the red heel clicker spring and weights? I may try yammie god's primary set up that he was pulling 110mph with.....any suggestions?
Any 2 or 4 stroke primaryu clutch from about 92 & up will work.
You blew a belt which in turn caused the primary to open & shut close instantly. The heel of the weight hit the sliding shive destroying everything.
Rule #1 running heelclickers...check belt often.
thanks turk....what weights/spring in primary would you suggest for me to use with my current secondary set-up?
PRIMARYS ARE A DIME A DOZEN, HERE , EBAY , etc. EARLY YAMAHA PRIMARYS WILL WORK, JUST REMEMBER TALL COVERS CAME OUT IN 98. 3:16 (yammie tony)
You can run a tall cover on an early short cover primary clutch.
just bolt on & go.
