Dr clutch spring, cams . 1980
Thunder101
Sk Canada
I have a mild modifided ET340 and have a SRV clutch spring and am having a Btch of a time dialing the clutching in. poo or cat stuff and this would have taken 20 min. VERY limited parts to try on the old Yami. What do most do with these Yami clutched ? btw new pins and weights.
is this the 2 weight clutch or the 3 weight clutch and what are you trying to acomplish as these clutches are not that bad to work with
Nutz
