bottom end 433-Phazer
Thunder101
Sk Canada
Ive read some info on here about phazer jugs on the exiter bottom end. Is the Exiter case diff from some of the other modles ? I see the crank throw is the same on alot of other models ? thx
they are not a direct bolt on the case needs machining plus you have to decide on use in the Phazer heads or the ex heads either way there is more machining involved check out vintagesleds .com in the customs section they have a how to there
