mxmantater746
i have an 01 SRX that i added viper rear shocks to. what length of shock for the front do i need to add to bring the front up? is there a different upper shock mount? i know the viper and XTC's mount different. any suggestion would be great. thanks
you can flip the SRX bracket and machine a little to accept stock shock..will raise everything about an 1".Do a SEARCH on it..it's in here somewhere...
livewire_101proof
i used a set of 15" ohlins i found on ebay when i did mine and it worked awsome. if for some reason you did wand more the mount trick works (if i remember right you swap sides also and didnt have to fabricate anything), or you can use viper trailing arms and spindles to get a little more ride height also. but mine was a really good match to the viper rear suspension, just using the 15 inch front shocks.
