02 SX Viper All Fuel Bars flashing as well as Low Fuel Symbol
NLViper
CBS Newfoundland
Hey guys its been a long time no post since getting my Nytro. Handed the Viper over to the wife and the sled is still going strong.
I have a small issue as I stated in the title. All my Fuel bars flash as well as the low fuel symbol and the warning light. It flash's for 8 times and then off again. Some times it goes back to normal but does not show the correct amount of fuel in the tank. For example on a full tank it would only show one or 2 bars.
I was speaking to one of one friends and he seems to think it is the SNDR unit. Any thoughtsÉ
Have broke 2 sender's in an SRX, they usually read empty, Could be your problem. Shine a light in the tank to see if its broke off. If not, get a piece of coat hanger and put a bend in it and hook the sending unit. Start the sled and move it up and down slowly to see if the gauge changes. If nothing happens, the sender it probably the problem.
Forgot to mention sometimes the contacts on the sender get worn, If you move the float to either side ( to make better contact) you may see the gauge spike.
