proper oil feed routing on 98' SRX
NY_SXR700
Rochester, NY
Website
www.sohonetworkx.com
I did not take this thing apart (so I don't know how it gets routed). I can see from the wear marks on the belly pan that the oil feed line from the tank to the pump, routed under the water cooling hose. I re-attached it the way I "think" it should be. I am just wondering if anyone as a photo laying around of how it was routed from the factory. I'll see if I can snap a photo so you can see what I am talking about. I don't see how it can go any other way. I just want to make sure it's right so it does not pull off on the trail. tks, doug
