Oil on Exhaust Pipe - Making a mess!
Iceman31
SK, Canada
On the pipe that is closest to the left hand side when sitting on the sled. Right where the pipe comes off the engine I have a mess that is oily. Does this mean I have a gasket gone bad? I am new to this sled and I want to do most things myself. Should I be looking at the gasket for the pipe or the gasket where the joint meets the motor? Or am I not on the right track at all?
Phazer or Srx? Phazer...I have no idea. Srx then I would tend to think its the O-ring on the power valve assembly. Some say its a common go to the hardware and pick one up others say get it from yamaha. Should be able to find a diagram in the tech section of assembly in exploded veiw fashion.
Sorry - yes on my SRX. If it is the Powervalve Gasket would that be in the inner gasket or outer (closest to hood) gasket? The O-Ring I assume in the diagram is the Oil Seal which is ahead of what I refer to the Inner Gasket. At the end of the season I am going to pull my power valves to clean them. So will likely replace all of this when that happens.
