Material under exhaust springs??????
bojisrx
iowa
Hey guys what kind of material do you used under mod pipe springs so your fresh pipes don't scratch. heat wise what have you guys found that work good??
The cloth header wrap works well. I use strips of high temp silicone rubber. I bought orgae silicone rubber strips which are 1/8" thk x 2" wide by 36" long. I cut strips wide enough to protect the pipe from the spring. I glued the strips to the pipe using ornage high temp. RTV sealant. I bough the silicone strips from McMaster Carr. You can check them out on the web.
yeah thanks guy got her done.... used some red heat hose and cut it into pieces works great...
