Viper limiter straps
mdkuni
Houghton Lake, MI
I was looking at adjusting my limiter straps on my 02 Viper and have been unable to. What is the easiest way to go about adjusting them? There is very little room to get a wrench in there and if I do I cannot get the nuts to move. Any ideas? Thanks.
First get the back up, place a block of wood, like 2x4 under the front of suspension, then put back down, this compresses a bit to make it easier to adj, it is a tight fit but with a 12mm wrench (i think) you can loosen the botton nut, then you can adj you straps, now i think the max recommended length is 35mm, but i have heard of guys going longer with no problems, i have longtravel'd SRX with Viper shocks and i run 35mm, hope this helps..........James
