jasonsrx
hey merry christmas all...
latley when i pull my srx over the headlight and guages dont turn on, they are delayed for like 5 mins, must be a bad wiring problem or something anyone know?
what year is the SRX??
load control relay needs replaced, there is a service bulletin on this, see your dealer, they have a kit that you put on to fix this, p/n- 90891-50137-00
could his harness be worn under the motor. We had to pull my buddys on his 99 SRX because the light would work at random as we rode.
Tod
Tod
The only problems I've had with my lighting system on my 99 SRX is I've had to replace a speedo bulb, and now my tach bulb is burned out. The sled only has 3500 miles, and it seems premature to already have to replace these bulbs. Oh well, its cheap and easy!
