Keep 600 or go to 700?
O's srx
VIP Lifetime Member
Cobourg, Ontario
just tore apart my brothers srx600 and behold, piston is toasted.
pieces where blown off the top side of the dome, and cylinder badly scored/ scratched/ gouged
so the delemma now,
rebuild the sled using stock pistons, cylinders, and so on, or
go to a 700srx motor.
any ones thoughts are welcome?
if i go to the 700, what will i need?
700 cdi? or any thing else?
thanks.
The 700 top end jugs, pistons & heads bolt onto the 600...same engine from the connecting rods up. You can use the 600 cDI...gives a little better timing advance.
PS...my company has a branch in Whitby & has talked about moving me there!!!
Turk, ...was relocated from Whitby to Calgary a few years ago, ...spent 5 yrs. in that area, ...Brooklin (just north of Whitby), great place and the snowbelt is just a bit North of Whitby.
Turk, in a swap from 600 to 700 in the srx, will the exhaust and powervalves stay the same? Thanks.
PJ
