1991 exciter 570 sparks once then none after that? what could it be? plz help thank you
Vmax540
-T.O.R.S bypass and try for spark
-Plugs
-CDI connection to wiring harness
-Stator connections and check coil resistance
-Shorted or open wire in the wiring harness
-Plugs
i just put new wiring on sled and started it up and ran fine then next day i went out to start it and wouldnt start. it would onlyspark once then spark goes away i bypassed tors ,checked all connections ,changed plugs.
Try bypassing or replacing the kill switch.
