what year was in mph mine is 2000 and is mph not k is my odometer in ks or miles
nvr2fst
huh? You need to put more info into this.... What is the machine you are speaking of?
srx 700 speedo is in mph i thaught they came in killometers
musselman
If it's from the states it will have mph and miles on the od.
musselman said:If it's from the states it will have mph and miles on the od.
X2 - if I understand your question... I believe MPH vs. KPH is dependent on where the sled was delivered/shipped to from Yamaha.
And it can be changed. This is for a Viper but the procedure should be the same http://www.totallyamaha.net/forums/showthread.php?t=67700&highlight=change+speedometer
Viper_Dave said:And it can be changed. This is for a Viper but the procedure should be the same http://www.totallyamaha.net/forums/showthread.php?t=67700&highlight=change+speedometer
I don't believe so if it's a 2000 SRX being that it's analog.
AH, silly me! Didn't even think about THAT LOL! Guess you could look for a used 1 and replace it.
