Styles211
I was wondering if the 99's had the problem of the wiring rubbing and shorting out under the motor. The reason I ask is that today when I fired it up the lights and the tack flickered on and off a few times and then it worked fine.
Thanks!
Styles
Thanks!
Styles
they all do it, I have fixed 98,99,2000(lots), not many 2001, its common, just unplug the harness up by the hood hinge on the pto side, then pull harness back under engine by the coolant tank, easy to do with airbox out and stuff out of the way, repair , then use the small auto conduit to help add some protection, your problems will be solved.
Styles211
Thanks for the info,does my symptoms sound like this could be the problem.
Styles
Styles
wiring
yeah, they do all kind of strange things, and usually only gets worse as time goes on. Take some time and fix it, youll be glad you did! have a great Holiday!!
coreysask
:-) The things I wish I would have done before it turned into a problem.
If you're lucky you can pull the wires enough to fix them without having to take the motor out. Pipes and airbox removed to get at them.
Consider wire looming around them once fixed so it doesn't happen again.
Corey
Corey
